tayto94 Posted May 25, 2011 Report Share Posted May 25, 2011 Sorry for the crude drawing of the swingarm but it was only done quick!! Just a simple pusher about .1mm narrower that the bearing outer race and .1mm narrower than the bearing inner race. Either use a press or hammer to push em out Quote Link to comment Share on other sites More sharing options...
neo Posted May 26, 2011 Report Share Posted May 26, 2011 No that's perfect....thanks But I assume you drove out both bearing cadges at the same time like this? Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
tayto94 Posted May 27, 2011 Report Share Posted May 27, 2011 No that's perfect....thanks But I assume you drove out both bearing cadges at the same time like this? Best of balance. Neo yep,both at same time, then used a long bush and pressed the bearings in from each side with the bush in place so they would be aligned right Quote Link to comment Share on other sites More sharing options...
