247 pivot sleeve removal
jc2
Can any Monty experts tell me if there's any tricks to removing the swingarm's pivot sleeeve (on a late 247)?
The swingarm is out of the frame & the pivot shaft/bolt is also out. But when I try to remove the sleeve, which presumably should just slide out of the bushes, it wants to 'pick up' the bush & push it thro the other side (whatever side I try) & basically just seizes up.
Has anyone had a similar problem & resolved it?
Am I missing some basic 'trick'?
Or is it just a case of using more force?
