ATF?
coxy
Hi everyone
I know that this question must of been covered hundreds of times on here but I'm wondering what ATF fluid to use, do you use a good make such as motul, castrol or putoline or do you just use any that's cheap?
I've seen some castrol tq d3 I think it is from my local halfords and some castrol dexron 2 stuff aswell both in 1 litre would either of these be any good?
Also at my local shop they stock putoline gp10 or light gear oil. Would you reccomend using this rather than the ATF fluid or not and why?
Cheers coxy!!
Dextron 3 really any make will work if it meets the requirements to be classed as dextron 3 then go for it. I have switched to Canadian tire house brand dextron 3 because its cheap $4.25 per L I just change my oil a little more often to cover my ass.
Later
Dustin
