smelling123 Posted April 30, 2011 Report Share Posted April 30, 2011 Hi, i have what I think is a 198, the frame number starts with 198 and then some numbers. The bike has the alloy bashplate/no frame rails at the bottom. Am I right in thinking the bashplate model was 198A and 198B? If so maybe mine has been converted - if it has then its a professional job and looks very much like others I have seen so Im not worried but it'd be nice to know. I'd have expected the frame number on a 198A or 198B to start with 198A (or 198B) not just 198... Any ideas? thanks Quote Link to comment Share on other sites More sharing options...
pschrauber Posted April 30, 2011 Report Share Posted April 30, 2011 Hi, i have what I think is a 198, the frame number starts with 198 and then some numbers. The bike has the alloy bashplate/no frame rails at the bottom. Am I right in thinking the bashplate model was 198A and 198B? If so maybe mine has been converted - if it has then its a professional job and looks very much like others I have seen so Im not worried but it'd be nice to know. I'd have expected the frame number on a 198A or 198B to start with 198A (or 198B) not just 198... Any ideas? thanks The frame number should start with two letters then a hyphen then comes 3 digits with the model number. like your mentioned 198 after that the serial number of that number, a or b models are marked by a second hyphen then comes the letter. Number as follows: AA-MMMXXXX-S A: letters M: model number X: serial number S: A or B model, (if none of this forget the hyphen and the S) Here as an example for the serial nuber of an 199b model: Quote Link to comment Share on other sites More sharing options...
smelling123 Posted April 30, 2011 Author Report Share Posted April 30, 2011 That explains it, many thanks for your help. Quote Link to comment Share on other sites More sharing options...
pedronicman Posted April 30, 2011 Report Share Posted April 30, 2011 (edited) more info- ##198##### 1978/1979 Badged as a '250' (238cc) 5 speed ,Silver frame /red mudguards,red side panels and red tank ##199##### 1978/1979 " '350' (325cc) 5 speed , Colours as above Both models above have frame rails under engine with grill type welded on bash plate ##198#####-A 1980 " '250' (238cc) 5 speed, Blue frame,blue mudguards ,blue side panels and blue tank ##199#####-A 1980 " '350' (325cc) 5 speed , Colours as above Both models above had NO frame rails ender engine but had a thick alloy bash plate instead ##198#####-B 1981 " '250' (238cc) 5 speed ,WHITE frame and white mudguards,blue side panels,blue tank,blue yokes and forks ##199#####-B 1981 " '350' (340cc) 6 SPEED Colours as above " " " Both models above had NO frame rails ender engine but had a thick alloy bash plate instead Edited April 30, 2011 by pedronicman Quote Link to comment Share on other sites More sharing options...
lorenzo Posted May 1, 2011 Report Share Posted May 1, 2011 (edited) Some further info. re 198 models as they left the factory - Frame with bottom tubes and welded bash plate used up to serial #19801769 Frame less bottom tubes and with alloy bash plate factory-fitted from serial #19801770. (according to the appropriate parts book, and unless someone out there knows differently, of course) Edited May 1, 2011 by Lorenzo Quote Link to comment Share on other sites More sharing options...
pedronicman Posted May 3, 2011 Report Share Posted May 3, 2011 (edited) Some further info. re 198 models as they left the factory -Frame with bottom tubes and welded bash plate used up to serial #19801769 Frame less bottom tubes and with alloy bash plate factory-fitted from serial #19801770. (according to the appropriate parts book, and unless someone out there knows differently, of course) 198 MODEL - Frame has bottom tubes and welded grille type bash plate 198A MODEL - Frame has NO bottom tubes and is fitted with alloy bash plate and strengthened swingarm Edited May 3, 2011 by pedronicman Quote Link to comment Share on other sites More sharing options...
