nosmokenopoke Posted May 5, 2011 Report Share Posted May 5, 2011 Hey guys i've recently bought a 06 gas gas 280 pro and im loving it but i find it a little bit slugish on the first bit of the throttle wen i go to jump or wheelie any help or ideas on what would be a good idea to check out with it ? :I've cleaned the carb out :I've adjusted the screw on the carb both ways in and out still no joy Quote Link to comment Share on other sites More sharing options...
cabby Posted May 5, 2011 Report Share Posted May 5, 2011 Slow action throttle ? Quote Link to comment Share on other sites More sharing options...
markwoodlief Posted May 5, 2011 Report Share Posted May 5, 2011 maybe too rich of a mix? I find that if i follow what gasgas says and mix 50:1 my bike hates it.. loads up all the time, etc.. which in turn would give you a 'sluggish' feel.. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 6, 2011 Report Share Posted May 6, 2011 Is this a dellorto carb bike? If so, ck to insure it is not only clean, but the jetting is correct as many times stock jetting is far too weak, at a #30 or so pilot. Getting up to 33-36 range can make a big difference! Quote Link to comment Share on other sites More sharing options...
nosmokenopoke Posted May 8, 2011 Author Report Share Posted May 8, 2011 Slow action throttle ? Could you elaborate a little bit more Not sure which carb s in it but i'll check. Quote Link to comment Share on other sites More sharing options...
jse Posted May 8, 2011 Report Share Posted May 8, 2011 Could you elaborate a little bit more Not sure which carb s in it but i'll check. Chances are you have the Dellorto PHBL and jetting for sea level up a couple thousand feet altitude should be in the neighborhood of: MAIN: 118 (116 OK, NOTHING SMALLER!) PILOT: 36 (38 OK) NEEDLE: D36 (3rd, or 2nd CLIP POSITION DOWN FROM TOP) FUEL SCREW: 3.5 TURNS OUT (screw on the side of the carb closest to the engine) FLOAT HEIGHT: ARMS IN LEVEL PLANE WITH FLOAT BOWL BASE (PARALLEL) Jon Quote Link to comment Share on other sites More sharing options...
