What is the difference
rock hopper
  On 5/7/2011 at 5:00 PM, Rock Hopper said:
I was wondering what is the different beteen a TLR 250 and a RTL 250 engine?
Cannot give you the technical arguement, but as a rider who has a 1986 RTL 250 and a 1987 TLR 250, they are like chalk and cheese. The RTL has vastly more power, across the full engine range. The TLR is much smoother (= flatter!!) and generally easier to ride, but much less capable of handling modern trials. For an average clubman, I would say the TLR is more manageable, but the RTL gives a bigger grin factor!
The engine internals on the RTL and TLR are basically the same, piston, valves, cam etc.
The RTL has a different ignition which gives a different power characteristic, smoother off idle than the TLR which in standard config is too sharp, prone to spit stall and doesn't rev out. Valve timing may differ as well.
Later RTL had a bigger clutch and different gear ratios.
Jerry - not sure which TLR you are referring to, the twinshock TLR wasn't made in '87, they were '84. The TLR250R was '87 but that was a different bike althogether, monoshock and a different engine.
Let me share you some engine Technical data:
The TLR250 Honda official data for Europe and US market was:
The ENGINE
Air cooled 4-stroke
Displacement: 249,8 cc
Bore and stroke: 70 X 64,9mm
Valve train: Overhead camshaft chain drive
Maximum Horspower: 15hp at 6.000rpm
Maximum Torque: 2 Kg/m at 4.000rpm
Compression ratio: 8.3:1
Ignition: CDI (Capacitor Discharge Ignition)
The RTL250 and RTL250S Honda official data for Europe and US market was:
The ENGINE
Air cooled 4-stroke
Displacement: 249 cc
Maximum Horspower: 14hp at 6.000rpm
Maximum Torque: 2,05 Kg/m at 4.000rpm
TLR250 had more power (1hp more) but less torque, 2Kg instead 2,05Kg
RTL250 weight was 6Kg lighter, 82Kg while TLR was 88Kg
Some Magazines at this time announced 16Hp for the RTL250 (No official data)
The Honda Trials History
