bengtphorqs Posted May 7, 2011 Report Share Posted May 7, 2011 Being 6ft 1" tall I find the TY250A a fun ride but would like to lower the pegs. I do have a peg lowering kit, used, but for the life of me can't see how to install it. Does anyone have any photos or suggestions? Quote Link to comment Share on other sites More sharing options...
tony283 Posted May 8, 2011 Report Share Posted May 8, 2011 You might like to use my "77 gets her 2008 Makeover" as a reference article. On the "Blog" published 7/28/2008. I do discuss the differences in the frames and how your 74 frame may be different. Tony Quote Link to comment Share on other sites More sharing options...
mattylad Posted May 11, 2011 Report Share Posted May 11, 2011 Most people use the bottom horizontal frame tube which is already threaded then cut off the footrest on the same vertical plane, drill and thread a 8mm hole. Cut out a triangular shaped plate drill and weld on footrest mounting bracket in desired position. Takes an afternoon but well worth the effort. Quote Link to comment Share on other sites More sharing options...
alan_nc Posted May 13, 2011 Report Share Posted May 13, 2011 (edited) Question on riding a TY250 with lowered foot pegs: Doesn't the seat/gas tank get to far up into your crotch when you lower the foot pegs making it harder to swing (tilt) the bike from side to side when turning? I have considered lowering mine for a couple of years but would love to ride one before I cut the current pegs off. Edited May 13, 2011 by Alan_nc Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 13, 2011 Report Share Posted May 13, 2011 Question on riding a TY250 with lowered foot pegs: Doesn't the seat/gas tank get to far up into your crotch when you lower the foot pegs making it harder to swing (tilt) the bike from side to side when turning? I have considered lowering mine for a couple of years but would love to ride one before I cut the current pegs off. Alan turning is not affected because your knees are still above the seat, but lowering the footpegs does reduce the clearance under your bum so when you unweight the rear end of the bike there is a higher chance that the seat or rear guard will hit your tailbone. Most commonly noticed when crossing big logs or jumping up an obstacle. Not a problem for people with long legs but I am 5'10" in your measurements and find that a couple of times I have hit my tailbone on the rear guard on my TY250 twinshock with lowered pegs when doing energetic unweighting of the rear end of the bike. Quote Link to comment Share on other sites More sharing options...
searay175 Posted May 31, 2011 Report Share Posted May 31, 2011 I just had my first outing on my ty250a after adding my own homemade brackets. It's different! The front end has become very light much like my 175 was. A slow pull up a steep hill with good traction and the front would start rising pretty easy but I will adjust. They do stick out aways. I measured 20" between the outside of the pegs but my GasGas is 19" The center of the pegs are 37 1/2" from the center of the front spindle. I will like them. Quote Link to comment Share on other sites More sharing options...
