eddyp Posted May 10, 2011 Report Share Posted May 10, 2011 Ive just replaced the clutch plates on my 315r with the Apico friction and dimpled metals, replaced the oil with PJ1 ultra light. The bike now has a clutch and goes into neutral easily. I have notived that it is a lot louder than the old clutch and when you pull the clutch lever in the clutch sounds as though its rubbing against the clutch casing, let go of the clutch lever again and no noise. I put my hand on the casing and pulled the lever in and im sure I could feel it working/ rubbing. I nipped the springs up OK so Im wondering if the new clutch is slightly thicker than the old one? Any thoughts Quote Link to comment Share on other sites More sharing options...
manofsteele Posted May 11, 2011 Report Share Posted May 11, 2011 Sorry, no clue here... However, I would be interested to know how your clutch performs over a few rides as I want to overhaul mine and don't know what brands are worth buying. Quote Link to comment Share on other sites More sharing options...
eddyp Posted May 14, 2011 Author Report Share Posted May 14, 2011 Well i had the clutch cover off today and found that clutch was rubbing the casing. Checked all the plates were located properly in the basket and pulled the lever in to check operation and all was ok. Put the casing back on and started her up only to find it rubbing again...not happy Quote Link to comment Share on other sites More sharing options...
