Random Fantic 240 questions
godzilla
I need to pick your brain's, im pretty close to getting my 240 in a rideable state but need a little random info.
The flywheel breather, do i need some clear pipe with 10mm id, how much do i need a where dose it got to?
Do i need 6mm fuel pipe or larger?
Can anyone tell me the thread length of the bolts that hold the chain guard on?
Can anyone give me any info on gearing 11-?
Cheers.
Edited by godzilla
Cheers.
breather pipe goes up frame to basicaly same place as airbox breather pipes,
6mm fuel pipe will be fine
push a thin nail into threads to measure how long bolts needs to be less approx 5mm, but they only need to go in 15mm or so.
  • 2 weeks later...
