godzilla Posted May 15, 2011 Report Share Posted May 15, 2011 (edited) I need to pick your brain's, im pretty close to getting my 240 in a rideable state but need a little random info. The flywheel breather, do i need some clear pipe with 10mm id, how much do i need a where dose it got to? Do i need 6mm fuel pipe or larger? Can anyone tell me the thread length of the bolts that hold the chain guard on? Can anyone give me any info on gearing 11-? Cheers. Edited May 15, 2011 by godzilla Quote Link to comment Share on other sites More sharing options...
furse Posted May 15, 2011 Report Share Posted May 15, 2011 I need to pick your brain's, im pretty close to getting my 240 in a rideable state but need a little random info. The flywheel breather, do i need some clear pipe with 10mm id, how much do i need a where dose it got to? Do i need 6mm fuel pipe or larger? Can anyone tell me the thread length of the bolts that hold the chain guard on? Can anyone give me any info on gearing 11-? Cheers. breather pipe goes up frame to basicaly same place as airbox breather pipes, 6mm fuel pipe will be fine push a thin nail into threads to measure how long bolts needs to be less approx 5mm, but they only need to go in 15mm or so. Quote Link to comment Share on other sites More sharing options...
grib Posted May 17, 2011 Report Share Posted May 17, 2011 11-39 works well for the gearing. Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 17, 2011 Author Report Share Posted May 17, 2011 Cheers folks Quote Link to comment Share on other sites More sharing options...
archie Posted May 26, 2011 Report Share Posted May 26, 2011 Are you entered for the Blue Bar this weekend godzilla ? Quote Link to comment Share on other sites More sharing options...
