peet Posted May 24, 2011 Report Share Posted May 24, 2011 I have 3 spokes that are bent, 2 in the front wheel and 1 in the rear wheel. Ordered new ones online. Do I have to take the tires off? Or can I just screw the old spoke out and put the new one in? Quote Link to comment Share on other sites More sharing options...
bigfoot Posted May 24, 2011 Report Share Posted May 24, 2011 Tyres off I'm afraid. Quote Link to comment Share on other sites More sharing options...
legionnair Posted May 27, 2011 Report Share Posted May 27, 2011 Why replace the bent spokes, just straighren them with plyers and ride it Quote Link to comment Share on other sites More sharing options...
hrc1 Posted May 27, 2011 Report Share Posted May 27, 2011 Plyers are too sofisticated, I use a hammer Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted May 27, 2011 Report Share Posted May 27, 2011 Hammers are too sophisticated, I use a stone. Quote Link to comment Share on other sites More sharing options...
jse Posted May 27, 2011 Report Share Posted May 27, 2011 Hammers are too sophisticated, I use a stone. For some perverse reason, Charlie, I believe you... Here's a little "trick" I've used for decades to bend or straighten parts, from spokes, subframes to sump shields and beyond. Two Cresent wrenches work very well, just imagine the pipe as a spoke or any part you want to put a lot of torque on and be able to easily control how much you want to bend. Better than a rock..... Jon Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted May 28, 2011 Report Share Posted May 28, 2011 For some perverse reason, Charlie, I believe you... Jon It's because you know I was a Harley mechanic! A rock is an official Harley tool that carries a "-03" suffix on the part number to denote the year it was introduced. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 28, 2011 Report Share Posted May 28, 2011 Harley Mechanic Quote Link to comment Share on other sites More sharing options...
totalshell Posted May 28, 2011 Report Share Posted May 28, 2011 you can change without even taking the wheel off.. i did three on my Yam road bike. keep tyre inflated... cut damaged spoke in half, wiggle the end on the hub out. unscreww other end from nipple ( inflated tyre will stop it falling into rim) get new spoke and insert hub end you ll probably find that spoke is too long to get into nipple even if you press nipple in so cut maybe 5mm from end of spoke and get in in.. tighten up all okay.. when riding abroad i kept have a dozen front and rear spokes ready cut tapped to the inside of my headlight cowl, only needed them once in 40k of continetal motoring on a campsite just outside Gyor in Hungary. Quote Link to comment Share on other sites More sharing options...
