gerko Posted May 24, 2011 Report Share Posted May 24, 2011 Does anybody have the bearing codes for the Needle bearings that fit the bottom suspension bracket. 4 in total , 2 on each side ,upper and lower.??? And the bottom shock spherical bush??? I could phone lampkins i know but they are mega expensive Thanks for any help Quote Link to comment Share on other sites More sharing options...
tufty Posted June 2, 2011 Report Share Posted June 2, 2011 (edited) Does anybody have the bearing codes for the Needle bearings that fit the bottom suspension bracket. 4 in total , 2 on each side ,upper and lower.??? And the bottom shock spherical bush??? I could phone lampkins i know but they are mega expensive Thanks for any help I measured the ones I knocked out of the swingarm, tapped the i/d, o/d and width into Simplybearings' site and hey presto. Most needle roller bearings start with HK then the internal diameter then the width. For example the swingarm on my techno is HK2218 RS Edited June 2, 2011 by Tufty Quote Link to comment Share on other sites More sharing options...
gerko Posted June 3, 2011 Author Report Share Posted June 3, 2011 (edited) Cheers mate , ive managed to replace all the roller bearing in the linkage at less than half the price that robbers Beta wanted . I'm struggling my a*** of to find a replacement spherical bush for the bottom of the shock though. beta £40 jokers Edited June 3, 2011 by Gerko Quote Link to comment Share on other sites More sharing options...
