zaccyboy Posted May 24, 2011 Report Share Posted May 24, 2011 Hi,the pads on my beta rev 3 ( 2003 )need changing, can anyone point me in the right direction and easy to follow instruction on changing them, its been a long while in attempting a task like as iv been out the motorbike sector for years. thank you Quote Link to comment Share on other sites More sharing options...
cabby Posted May 24, 2011 Report Share Posted May 24, 2011 Most brakes are pretty much the same, remove from fork, undo bolt on right hand side of caliper, remove pin oppisite bolt, pads fall out, repeat t'other way round. Quote Link to comment Share on other sites More sharing options...
totalshell Posted May 24, 2011 Report Share Posted May 24, 2011 piece of cake they'll fall out! whip the reservoir caps/ lids off when you push the cylinders back into the calipers and you ll wonder what you worried about.. put some coppa silp on the back so they dont squeal.. Quote Link to comment Share on other sites More sharing options...
hrcmonty Posted May 25, 2011 Report Share Posted May 25, 2011 (edited) As i've said in another post. It looks like i'm advertising, but im not. It's just that Trials uk have some good easy to follow How 2 videos on their site, that cover things like this. Have a look, there Banner pops up all over Trials Central. Edited May 25, 2011 by hrc_monty Quote Link to comment Share on other sites More sharing options...
zaccyboy Posted May 25, 2011 Author Report Share Posted May 25, 2011 hi guys, thanks for your advice, much appreciated. Quote Link to comment Share on other sites More sharing options...
adam1 Posted May 25, 2011 Report Share Posted May 25, 2011 hi guys, thanks for your advice, much appreciated. Dont do what i have just done and strip the the bolt in the caliper Adam Quote Link to comment Share on other sites More sharing options...
zaccyboy Posted May 26, 2011 Author Report Share Posted May 26, 2011 hrc_monty I see what you mean re Trails UK how to videos, very good tutorials. Quote Link to comment Share on other sites More sharing options...
pauldalgarno Posted May 26, 2011 Report Share Posted May 26, 2011 Also, don't squeeze the brake lever while the caliper's off, you might pop the piston seals. I do it often, and it's annoying to have to bleed the brakes when you don't need to.... Quote Link to comment Share on other sites More sharing options...
pauldalgarno Posted May 26, 2011 Report Share Posted May 26, 2011 Dont do what i have just done and strip the the bolt in the caliper Adam I've also done this with the exhaust flange on the cylinder head. Helicoils repair sets are excellent! A bodger's dream, but practice on something less valuable than a cylinder head, or fork leg first! Quote Link to comment Share on other sites More sharing options...
adam1 Posted May 27, 2011 Report Share Posted May 27, 2011 Yeah hellicoil is the one! Planning on doing it this weekend at some point Quote Link to comment Share on other sites More sharing options...
