gas_gas_96 Posted May 26, 2011 Report Share Posted May 26, 2011 hi. ive wrote on this forum before and everybody is really helpful and kind, anyway my 96 gas gas jtr is 5 up 1 down like most bikes, and if i ride in gear 2 and cut it out, then i go down 2 and its not in nuetral, however it will still go down another gear? i think it is something in the gearbox that is knackered but i dont know anything if im honest, i just want it to run properly it had a bunch of problems and ive fixed them all this is all thats left now...... thanks jack Quote Link to comment Share on other sites More sharing options...
t-shock 250 Posted May 26, 2011 Report Share Posted May 26, 2011 (edited) A.The gears won't select if you've turned the engine off, you think you're going down 2 gears but i bet its still in second. B. Your gearbox is actually 1 down and 5 up (not 5 up & 1 down) so you think you're in 2nd but your actually in 3rd. Edited May 26, 2011 by t-shock 250 Quote Link to comment Share on other sites More sharing options...
monty_jon Posted May 26, 2011 Report Share Posted May 26, 2011 (edited) On 5/26/2011 at 9:23 AM, gas_gas_96 said: hi. ive wrote on this forum before and everybody is really helpful and kind, anyway my 96 gas gas jtr is 5 up 1 down like most bikes, and if i ride in gear 2 and cut it out, then i go down 2 and its not in nuetral, however it will still go down another gear? i think it is something in the gearbox that is knackered but i dont know anything if im honest, i just want it to run properly it had a bunch of problems and ive fixed them all this is all thats left now...... thanks jack Its very hard to select gears with any accuracy without the motor running (best practice is to stop motor in neutral) Best to run thought all the gears when riding, if you have six gears and it changes ok then all is fine Edited May 26, 2011 by Monty_Jon Quote Link to comment Share on other sites More sharing options...
rustybay Posted May 26, 2011 Report Share Posted May 26, 2011 Hi Jack Ive the same bike and have had the same problem. the fault is a worn gear selector. You will need to remove the clutch casing off and you can see a flat plate that hooks onto the gear selector pins. Gas gas do have thease parts or you can reshape the plate Hope this helps wayne Quote Link to comment Share on other sites More sharing options...
jonnybmac Posted May 26, 2011 Report Share Posted May 26, 2011 Also neutral is in between 1 & 2. Not a full shift but only half to get there Quote Link to comment Share on other sites More sharing options...
gas_gas_96 Posted May 27, 2011 Author Report Share Posted May 27, 2011 On 5/26/2011 at 8:46 PM, rustybay said: Hi Jack Ive the same bike and have had the same problem. the fault is a worn gear selector. You will need to remove the clutch casing off and you can see a flat plate that hooks onto the gear selector pins. Gas gas do have thease parts or you can reshape the plate Hope this helps wayne hi wayne, thanks this is very helpful, do you know exactly where i can get the parts too? thanks jack Quote Link to comment Share on other sites More sharing options...
