starting
original
Agree Air filter oil does not evaporate but solvent carrier does when you use spray filter oil. It seems to be the build up of the solvent in air box that upsets things.
When stopping the bike with the kill button is there a programmed stop? - ie fuel off or does it just stop the spark like a basic carb bike?
Hello
It is an interesting discusssion, you have started here. If in seeking more information about how Honda Montesa 4RT ecu work, I highly recommend reading the following patent from Honda Motor Co. Ltd. 'Vehicle-mounted internal combustion engine controller with inclination sensor. "
I hope it will shed some light on how Honda's ecu works.
Follow this link. Honda Patent
Best regards
Honda Freak
Edited by Honda_Freak
