sting32 Posted March 9, 2005 Report Share Posted March 9, 2005 From this page... PS I have an 04 300Pro, so it has me wondering... http://www.gasgasmotos.es/eng/frame.htm (not sure maybe they copied this directly from the 04 page?) But it would seem that they have updated the clutch once again? Wonder what EXACTLY ALL parts they changed, if so? Plus now I would be confused, the 'mineral oil' used in the clutch hydralics? is that in 05 only, maybe overseas only? luckily I havent had the problem like in the past with knocking banjo fitting around, causing air to get in it... but surely I will at some point, just as before... so I need to know if I need new fluid to keep on hand, ya know. Anyone out there know? Quote Link to comment Share on other sites More sharing options...
jtt Posted March 9, 2005 Report Share Posted March 9, 2005 Somehow I managed to delete my own post... Sting Click Here and download the '05 parts manual. You can tell the year of the part update by the part number. MT280345677 is from '03, MT280545677 is from '05 The '05s are apparently using the mineral oil based hydraulics like last years Raga replica, so you'll likely see a new line and new reservoir cap (stamped mineral oil, rather than DOT4) Hope this helps clear the confusion some. Quote Link to comment Share on other sites More sharing options...
bob Posted March 9, 2005 Report Share Posted March 9, 2005 I used to have a disk brake which used mneral oil, you can pick it up from halfords. Don't use Dot oil as it will corrode the seals. Quote Link to comment Share on other sites More sharing options...
sting32 Posted March 11, 2005 Author Report Share Posted March 11, 2005 Eggcellent point, I had the 04 despiece pdf (parts breakdown), and the o5 I just got thanks to you, Well, same part #'s for the fiber plates, But it would seem, that the steel plates must have changes. Hmmm. Printing off the pages for both parts-breakdowns, to examine more closely Quote Link to comment Share on other sites More sharing options...
spokes Posted March 11, 2005 Report Share Posted March 11, 2005 Is mineral hydraulic oil the same as LHM fluid that is used in Citroen Hydroelastic Suspension systems ? Can I use it in my brakes and clutch ? Will it give better feel ? I have tons of the stuff (LHM) in the back of the shed somewhere !!! Quote Link to comment Share on other sites More sharing options...
