4rt gear oil type
dye29
hy has anyone got a good oil to use for 4rt gear oil iv used motul and silkolene there ok but after couple of trials the clutch makes a wining noise when flicking clutch or setting off slow its ok when fresh oil in also just put elf htx in and same problem but straight away this time help regards ste
hi bought a 06 4rt nine months ago been using dexron 11 atf i change it after four practice days had no problems with clutch, my bike has the 315 clutch res upgrade, advised the previous owner had fitted apico clutch plates ? im told that there is a upgrade involving the clutch plates from a cr 125 ? other members may no more im told these plates are dimpled reducing clutch drag hope this helps
I've used Maxima 75wt synthetic gear oil in my 06 since it's first oil change, works great. The clutch is original, the master cylinder has been changed to the large body as used on the 315.
