7 Posted May 29, 2011 Report Share Posted May 29, 2011 problem with cooling fan,when the fan comes on and you rev the bike the fan gets faster and sounds louder than norm changed fan and fan rectifier problem still there, Quote Link to comment Share on other sites More sharing options...
lowbrow Posted May 29, 2011 Report Share Posted May 29, 2011 Every GasGas I've owned has done this. Why do you think its a problem? Quote Link to comment Share on other sites More sharing options...
7 Posted May 29, 2011 Author Report Share Posted May 29, 2011 Every GasGas I've owned has done this. Why do you think its a problem? hi,not a problem still does its job fine,did a trial yesterday,just find it strange Quote Link to comment Share on other sites More sharing options...
lowbrow Posted May 29, 2011 Report Share Posted May 29, 2011 (edited) Its just that the generator coil doesn't produce enough umph at low revs; quite normal. Edited May 29, 2011 by Lowbrow Quote Link to comment Share on other sites More sharing options...
7 Posted May 29, 2011 Author Report Share Posted May 29, 2011 Its just that the generator coil doesn't produce enough umph at low revs; quite normal. when you say generator coil is this on the stator plate,this is a 2010 bike,had 11 txt pros and never had this happen do you think i should have the stator plate checked Quote Link to comment Share on other sites More sharing options...
lowbrow Posted May 29, 2011 Report Share Posted May 29, 2011 I guess its easy enough to check using a meter in line somewhere, but don't know what the output readings from the coil should be although a search of this forum might turn something up or your dealer may have the data. If you're worried then test it for peace of mind but I've always found that the fan speeds up as the revs rise until the rectifier stops it getting too much juice. Are you saying that the fan won't run until you rev the motor? If yes, then I'd agree there's something wrong. Quote Link to comment Share on other sites More sharing options...
7 Posted May 29, 2011 Author Report Share Posted May 29, 2011 I guess its easy enough to check using a meter in line somewhere, but don't know what the output readings from the coil should be although a search of this forum might turn something up or your dealer may have the data. If you're worried then test it for peace of mind but I've always found that the fan speeds up as the revs rise until the rectifier stops it getting too much juice. Are you saying that the fan won't run until you rev the motor? If yes, then I'd agree there's something wrong. when bike gets to temp fan kicks in if you let it tick over there is very littlefan noise thanks for your input,going to keep useing it see if any thing happnes Quote Link to comment Share on other sites More sharing options...
