montesa 310 kickstart gears
tumble
not available new in this country , but cota 242 304 307 309 gears will fit with or without minor mods .i take it that its the toothed ratchet gear on the kickstart shaft or the double idler gear or both that have shed teeth .let us know which one(s)
Hi thanks for the reply, it's the double idler gear that's shed teeth
try www.bmz.fr , can only buy as a set from here . no probs with buying or deliveries . or www.vallmoto.com , can buy seperate here . took 2 months to deliver + only after paypal dispute .
if kickstart ratchet gear teeth are bent / twisted replace both or it will happen again v. quickly .
if you can fit decompressor to help start +/or retard ignition a touch if it kicked back when teeth broke
Thanks again, will have a look, yeah was getting bad kick back when it went will give it a try, any idea if 200 start gear would fit???
