dye29 Posted May 30, 2011 Report Share Posted May 30, 2011 hy iv got a pw50 for youngen but its frame and wheel are abit tatty whats the best way and what paint to buy to spray paint the frame and wheels regards ste Quote Link to comment Share on other sites More sharing options...
totalshell Posted May 30, 2011 Report Share Posted May 30, 2011 get em done in two pack be done in a couple of hours and will look mint see my tank was done in 15 minutes Quote Link to comment Share on other sites More sharing options...
dye29 Posted May 30, 2011 Author Report Share Posted May 30, 2011 On 5/30/2011 at 6:40 PM, totalshell said: get em done in two pack be done in a couple of hours and will look mint see my tank was done in 15 minutes that looks really good what prep work do i need and do i need primer ect also where do i get two pack from regards ste Quote Link to comment Share on other sites More sharing options...
monty_jon Posted May 30, 2011 Report Share Posted May 30, 2011 (edited) On 5/30/2011 at 6:50 PM, dye29 said: that looks really good what prep work do i need and do i need primer ect also where do i get two pack from regards ste Be aware that 2k paint is very dangerous, it contains isocyanide I get some decent results with cellulose paints Edited May 30, 2011 by Monty_Jon Quote Link to comment Share on other sites More sharing options...
dye29 Posted May 30, 2011 Author Report Share Posted May 30, 2011 can this be done via spray can also what is needed to prep and where to buy im after a gloss black like your frame Quote Link to comment Share on other sites More sharing options...
ormplus Posted May 30, 2011 Report Share Posted May 30, 2011 go to your local paint supplier and they will mix and put it in an aerosol tin to what you want,but you will be beter using cellulose+ it drys quicker. Quote Link to comment Share on other sites More sharing options...
dye29 Posted May 30, 2011 Author Report Share Posted May 30, 2011 On 5/30/2011 at 8:31 PM, ormplus said: go to your local paint supplier and they will mix and put it in an aerosol tin to what you want,but you will be beter using cellulose+ it drys quicker. i dont no anyone local any other ideas Quote Link to comment Share on other sites More sharing options...
monty_jon Posted May 30, 2011 Report Share Posted May 30, 2011 (edited) On 5/30/2011 at 9:46 PM, dye29 said: i dont no anyone local any other ideas I use a small HVLP spray gun its very good for bike parts, you can get the cellulose paint off ebay or a local paint supplier Use anti-bloom thinners & jet-black paint for the frame. Make sure you prep well with wet & dry and a good coat of primer first Use a spray gun like this, better than cans and lasts years! gun Edited May 30, 2011 by Monty_Jon Quote Link to comment Share on other sites More sharing options...
ormplus Posted May 31, 2011 Report Share Posted May 31, 2011 try your local motor factors,if they dont have they should be able to tell you where. Quote Link to comment Share on other sites More sharing options...
captainslackdabber Posted June 5, 2011 Report Share Posted June 5, 2011 Personally I'd get it powder coated. It's a little more expensive than having it painted, but I had my Beezer frame done in 1992 and it's still good. As has been pointed out, 2 pack is in fact deadly dangerous. I'd avoid using it without proper safety kit. Quote Link to comment Share on other sites More sharing options...
gjbiker Posted June 5, 2011 Report Share Posted June 5, 2011 Tough and durable - Clicky Here GJ Quote Link to comment Share on other sites More sharing options...
eazyste Posted June 6, 2011 Report Share Posted June 6, 2011 Dye29, i see your at Scarborough, If you dont mind a bit of travelling, Rhomax at stockton will powder coat the frame for approx Quote Link to comment Share on other sites More sharing options...
dye29 Posted June 11, 2011 Author Report Share Posted June 11, 2011 On 6/6/2011 at 12:45 AM, eazyste said: Dye29, i see your at Scarborough, If you dont mind a bit of travelling, Rhomax at stockton will powder coat the frame for approx Quote Link to comment Share on other sites More sharing options...
eazyste Posted June 12, 2011 Report Share Posted June 12, 2011 im not sure about trials wheels, i'd reckon about Quote Link to comment Share on other sites More sharing options...
dye29 Posted June 12, 2011 Author Report Share Posted June 12, 2011 On 6/12/2011 at 3:54 AM, eazyste said: im not sure about trials wheels, i'd reckon about Quote Link to comment Share on other sites More sharing options...
