ausy300pro Posted June 7, 2011 Report Share Posted June 7, 2011 Has anyone got a spacer for the non brake side for front wheel or can anyone make one from dimensions of their own, I have either lost mine or didn't realise I had not received it when I bought the suzuki front end. Also has anyone machined off the normal handlebar (i.e. tiller type position) and put clamps on in a more modern position ? Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted June 8, 2011 Report Share Posted June 8, 2011 I may have a spacer, I will look when I get home. Yes I had a bike recently that had the original mounts milled off and Renthal bar mounts bolted on and it worked very well. Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted June 8, 2011 Author Report Share Posted June 8, 2011 Thanks very much (hopefully) Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted June 10, 2011 Report Share Posted June 10, 2011 Sorry can't find one but the dimesons are 12mm ID, 19mm OD and 25mm length. 09180-12057 is the part number. Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted June 10, 2011 Author Report Share Posted June 10, 2011 HI Thanks for help, don't suppose you know if it is available form crooks (for instance) if not will get one made. Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted June 11, 2011 Report Share Posted June 11, 2011 Sorry I have no idea if it's available or not, try your local dealer frist in case it's a common part or e-mail Crooks. Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted June 11, 2011 Author Report Share Posted June 11, 2011 Thanks, found out part is obsolete from Crooks website, did locate part using your part number (thanks), slightly different dimensions according to crooks though, it is only 22mm wide rather than 25mm according to their spec on part, will have to get something made, will go to 25mm easier to take a little off than put some back on ! Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted June 12, 2011 Report Share Posted June 12, 2011 Crooks dimensions are different because there is a 3mm washer/spacer of about 25mm OD either of the wheel, one by the spacer and the other between the brake plate and the fork leg. Quote Link to comment Share on other sites More sharing options...
ausy300pro Posted June 12, 2011 Author Report Share Posted June 12, 2011 OK thanks that explains it. Quote Link to comment Share on other sites More sharing options...
