alvin123 Posted June 7, 2011 Report Share Posted June 7, 2011 Hi, been having some running issues. Cleaned carb, new plug fitted. Started bike for a few mins at weekend, switched off and checked coolant. Cap was more pressurised than usual. I rode tonight and coolant was leaking out of over flow, and still missfires just off idle. I have replaced head seals a few months back. I was thinking a water pump issue, perhaps do these cause water into cylinder, crankcase? If faulty. I was going to call gas gas tomorrow, but was wondering if there are any none faults? Thanks in advance. Alan. Quote Link to comment Share on other sites More sharing options...
tltel Posted June 9, 2011 Report Share Posted June 9, 2011 Hi Alan just a thought, Have you checked wiring? Is fan working? If fan isnt working would cause water to come out of over flow, and maybe a connection fault making misfire. TLTEL Quote Link to comment Share on other sites More sharing options...
alvin123 Posted June 18, 2011 Author Report Share Posted June 18, 2011 Worked it out, head was cracked. Quote Link to comment Share on other sites More sharing options...
