teeth Posted June 8, 2011 Report Share Posted June 8, 2011 ey up Been out on the Beta for a bit tonight, and have a small problem occur The bike started fine then with a little speed (10mph or so) developed a timely 'tick' which makes me think it may be something on the chain BUT as this was going on the bike started going funny & cut out. Someone i spoke to at swaine was telling me Betas may tick when running low on fuel as he said this the carb peeeeed fuel out of the overflow! Now this is my first Beta, only ever had GasGas' can anyone shed any light on it? thanks Elliott Quote Link to comment Share on other sites More sharing options...
totalshell Posted June 9, 2011 Report Share Posted June 9, 2011 did you check if you had any fuel left.. did you run on reserve.. if the bikes running out of fuel it will normally rev a bit or 'fluff' ( when it happens you know whats happening) Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted June 9, 2011 Report Share Posted June 9, 2011 ey up Been out on the Beta for a bit tonight, and have a small problem occur The bike started fine then with a little speed (10mph or so) developed a timely 'tick' which makes me think it may be something on the chain BUT as this was going on the bike started going funny & cut out. Someone i spoke to at swaine was telling me Betas may tick when running low on fuel as he said this the carb peeeeed fuel out of the overflow! Now this is my first Beta, only ever had GasGas' can anyone shed any light on it? thanks Elliott Could be floats and needle jet stuck if its run out of fuel and then gone onto reserve. Take the carb off , clean thoroughly with compressed air and try again. Phil Quote Link to comment Share on other sites More sharing options...
teeth Posted June 12, 2011 Author Report Share Posted June 12, 2011 now then cheer for the reply, turns out bike was teetering on the reserve limit, could have sworn it had more fuel in!! As for the ticking - the front sprocket had a chipped tooth!! thanks again Quote Link to comment Share on other sites More sharing options...
deminimis Posted June 14, 2011 Report Share Posted June 14, 2011 (edited) now then cheer for the reply, turns out bike was teetering on the reserve limit, could have sworn it had more fuel in!! As for the ticking - the front sprocket had a chipped tooth!! thanks again Also make sure your master link clip isn't making contact anywhere. Makes a nice tick sound. Yup, I did that once. Edited June 14, 2011 by deminimis Quote Link to comment Share on other sites More sharing options...
