yamty175 Posted June 9, 2011 Report Share Posted June 9, 2011 Has anyone recycled their lighting coil as an ignition source coil? Reason I'm asking is the PO ran without a flywheel cover gasket and everything on the stator plate looks minging. I have a couple of lighting coils on my other TYs which are redundant and I'd like to use as a cheap fix. Thanks, Jonny. Quote Link to comment Share on other sites More sharing options...
andy.t Posted June 9, 2011 Report Share Posted June 9, 2011 Never tried it to see what would happen but the lighting coil output would be completely wrong for use on the primary HT coil. Give it a go..probably will burn something else out though. Go electronic its well worth the Quote Link to comment Share on other sites More sharing options...
yamty175 Posted June 14, 2011 Author Report Share Posted June 14, 2011 Thanks Andy.T. Reaching for my wallet. Jonny. Quote Link to comment Share on other sites More sharing options...
