bruces670 Posted June 11, 2011 Report Share Posted June 11, 2011 (edited) has anybody else noticed that very slight rattle on 250 evos particulary obvious at cold or on overun it does seem to change tone slightly when depressing clutch,its evident on both my 2010 and 2011 bikes but has never caused a problem? just done a bit of research on google and it seems to point toward the clutch basket??? Edited June 11, 2011 by bruces670 Quote Link to comment Share on other sites More sharing options...
dgshannon Posted June 14, 2011 Report Share Posted June 14, 2011 has anybody else noticed that very slight rattle on 250 evos particulary obvious at cold or on overun it does seem to change tone slightly when depressing clutch,its evident on both my 2010 and 2011 bikes but has never caused a problem? just done a bit of research on google and it seems to point toward the clutch basket??? Three days and no replies, so I guess not. Maybe it is your helmet rattling. Quote Link to comment Share on other sites More sharing options...
davelewis Posted November 20, 2011 Report Share Posted November 20, 2011 has anybody else noticed that very slight rattle on 250 evos particulary obvious at cold or on overun it does seem to change tone slightly when depressing clutch,its evident on both my 2010 and 2011 bikes but has never caused a problem? just done a bit of research on google and it seems to point toward the clutch basket??? Yes my 2011 250 rattles in the clutch area. Is it going to be ok? Quote Link to comment Share on other sites More sharing options...
copemech Posted November 21, 2011 Report Share Posted November 21, 2011 Yes my 2011 250 rattles in the clutch area. Is it going to be ok? Long story made short, clutches and gears tend to rattle a bit, specially at idle and not under load, this is normal. All has to do with normal mechanical clearances and engine pulsations. Yes, may change with clutch application as load and rotating components change a bit. May also increase with heat and thinning of gearbox oil. Quote Link to comment Share on other sites More sharing options...
smalley250 Posted November 21, 2011 Report Share Posted November 21, 2011 The gears in a trials bike are cut in a way for strength not for noise like in a modern car, hence the noise issue. Me old Gasser 07 rattled like a hell on the clutch but had no wear, just the design. Quote Link to comment Share on other sites More sharing options...
