davybull Posted March 11, 2005 Report Share Posted March 11, 2005 I've stripped the wiring out of my 2001 TXT today, but I have a slight problem in that I now only have one wire to the thermostat that I presume switches the fan on! The blue wire is still there but the yellow wire ran into the loom to the handlebars! Where should I connect the other terminal of the thermostat? Should I just find a live feed? The machine starts and runs fine but it's just this one problem..... Any help greatly appreciated. Quote Link to comment Share on other sites More sharing options...
richywrecka Posted March 11, 2005 Report Share Posted March 11, 2005 Sorry not to clever the wiring colours on gas gas, but dont connect your thermostat wire to a live feed, it should only be connected to the earth feed to the fan which will already have a live feed, the thermostat sends the earth to the fan to make it work. There is a way to test, if you start the bike and connect a wire to a good earth on the bike and try the other end in some of the connectors to see which one makes the fan turn on, the one that does is the one you need to connect the thermostat wire to. Hope this helps. also make sure when you find it to run the bike and make sure the fan kicks in. Richard. Quote Link to comment Share on other sites More sharing options...
davybull Posted March 11, 2005 Author Report Share Posted March 11, 2005 Anyone got a wiring diagram for this 2001 TXT 249? Here's hoping! Quote Link to comment Share on other sites More sharing options...
spokes Posted March 11, 2005 Report Share Posted March 11, 2005 R2 you beat me to it !!! Quote Link to comment Share on other sites More sharing options...
davybull Posted March 11, 2005 Author Report Share Posted March 11, 2005 Spot on guys. Mucho Grassi a***. Dave. Quote Link to comment Share on other sites More sharing options...
davybull Posted March 11, 2005 Author Report Share Posted March 11, 2005 Swearing checker works then eh.......... Cheers again guys one soldered joint sorted it out. Now done. Just gotta get the bugger registered now! Quote Link to comment Share on other sites More sharing options...
