TY175 will run but not rev
tytony
Hi, just had my TY rebuilt, it would'nt run properly when I bought it so thought I would have the engine rebuilt.
Had new bearings, rod, piston (not genuine, from ebay ?) points, condenser, Wes pipe, and stainless front pipe.
Will run, just, starts first kick but wont rev. Pulling choke makes no difference. When I bought it the guy had put a new carb on it but its not the 525 Mikuni. Am I waisting my time until I get the right carb ?
Cheers
Sounds like timing needs advancing... Move it slightly too far and it will pop and bang! Dead easy to try and costs nothing... Moving the points slightly to the right on the plate should do it - a hundredth of a mm
.... Could be carb of course!
  • 2 weeks later...
Does seem to point to carb, what with it being the same before as after the rebuild and the none stock carb being fitted.
First check the timing though.
Contact me if you'd like to try a stock carb, I have one and I'm in London.
