alan_nc Posted June 20, 2011 Report Share Posted June 20, 2011 I'm sure this has been covered before but I didn't find it: Need to replace the seals on my TY250 (1974). Can I do this without splitting the cases? If I can...how do you get the old seals out? Also any hint/tricks for putting the new seals in. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted June 20, 2011 Report Share Posted June 20, 2011 (edited) Alan both seals can be changed without splitting the cases. RH seal requires removing the gear on the end of the crankshaft and LH seal requires removing the flywheel and ignition stator plate. I use a self tapper screwed into the LH seal to pull it out. The RH seal runs on a spacer so it is even easier to get out once you slide the spacer out. I fit mine with a little oil on the OD so they slide in smoothly. Edited June 20, 2011 by feetupfun Quote Link to comment Share on other sites More sharing options...
stork955 Posted June 20, 2011 Report Share Posted June 20, 2011 Gday, and further to Feetup's advice, dont forget to grease the inner lips of the seals as well - otherwise they will last as long as it took you to fit them... Cheers, Stork Quote Link to comment Share on other sites More sharing options...
yamty175 Posted June 21, 2011 Report Share Posted June 21, 2011 For future reference, would the same proceedure be used for a TY175? Thanks, Jonny. Quote Link to comment Share on other sites More sharing options...
