charliechitlins Posted March 12, 2005 Report Share Posted March 12, 2005 One of my old riding buddies from where I used to live is lost without his underpaid mechanic (me), and he's having trouble with the clutch dragging on his late ('02, '03?) Scorpa. Major drag...he has to be rolling to put it in gear. He'll probably haul it REAL far for me to fix while he stands there, so there will be no option to not get it fixed. Anybody experienced this? The clutch problem, I mean...not somebody who isn't paying you staring over your shoulder. I know how to check all the basic stuff, but does anybody know anything peculiar to Scorpa clutches? It's been a while since I've seen the bike, but he says there's no bleeder on the clutch slave. Possible? Quote Link to comment Share on other sites More sharing options...
boofont Posted March 12, 2005 Report Share Posted March 12, 2005 Don't want to state the obvious but has he changed his oil? Its a sure sign on my SY that the oil is shagged when I select a gear (usaually from cold) and the bike trundles round with the clutch in. Quote Link to comment Share on other sites More sharing options...
steveo Posted March 12, 2005 Report Share Posted March 12, 2005 Hey BF,What brand oil and how often do you service your SY. Have you ever found clutch drag to be a problem when you do regular oil change. Steveo Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted March 12, 2005 Author Report Share Posted March 12, 2005 boofont said: Don't want to state the obvious but has he changed his oil? Its a sure sign on my SY that the oil is shagged when I select a gear (usaually from cold) and the bike trundles round with the clutch in. What oil are you using? Although...he stays in pretty good contact with Komer, and I'm pretty sure he put in fresh, recommended oil. Quote Link to comment Share on other sites More sharing options...
robee Posted March 12, 2005 Report Share Posted March 12, 2005 It can drag like that in cold weather for the first five to ten seconds especially if the oil is thick and/or old. It will also drag if there is too much oil in there. First try changing the oil. I believe the recommended amount is 650 ml but it works much better at 500-550 ml. Maybe there is too much in there now. Quote Link to comment Share on other sites More sharing options...
petej Posted April 3, 2005 Report Share Posted April 3, 2005 I had exactly the same problem on my '02 model. I stripped the clutch basket down, lightly sanded the ferodo'ed plates using some wet and dry on a flat surafce as they looked a bit too polished and reassembled it all. I put in some fresh oil at the recommended level. Worked for me. Quote Link to comment Share on other sites More sharing options...
