Cota 200 - Help Needed
glenn
Hi lads hope you will be able to help me out. I have a Montesa cota 200 and have a bit of a problem with the gearbox on it. When riding up hill it has a tendency to jump out of gear, has anyone had similar problems on this bike and if so what was it. I had an Ossa that had a similar fault and it was the spring for the detent plunger had snapped, is there a one of these fitted to this bike or is it a different system. Any help would be gratefully received.
Cheers Glenn
