kevinbouy1888 Posted June 28, 2011 Report Share Posted June 28, 2011 hiya could any one have an idea on how to remove the BOTTOM yoke on the 2006 beta aye have removed top bolt the yoke and the other bolt then the cover n washer but there is a what looks lika a spacer on top off the tapperd barring there is no other bolt at bottem off yoke and this what a amagen washer is stuck on SOILD HELPPPPPP PLZ Quote Link to comment Share on other sites More sharing options...
02-apr Posted June 28, 2011 Report Share Posted June 28, 2011 If you have removed the threaded ring then a tap with a hammer (soft faced) should move the stem. Quote Link to comment Share on other sites More sharing options...
kevinbouy1888 Posted June 28, 2011 Author Report Share Posted June 28, 2011 the threded ring the one ontop off the barring a tried taping this aswell but no luck Quote Link to comment Share on other sites More sharing options...
02-apr Posted June 28, 2011 Report Share Posted June 28, 2011 If you can see the bearing itself then you have removed everything necessary. If it does not respond to sensible use of the hammer then something is wrong but I can't think what. Quote Link to comment Share on other sites More sharing options...
