My New Old Sherco
chuckmorris
  • Replies 31
Later model guards do fit, looks to have a fairly late model white guard on it to me
When I had a 01 I ended up fitting the later model front caliper for an improved brake, you need to change the disc guard at the same time though
An '01 Sherco is a great bike. Smooth and bulletproof.
I really miss mine.
A 2 piston caliper from a later model will bold right on and is a sensible update.
I think the "01 also has a 1-piece brake pedal and the later one with hinged end is another good update.
Confirmed :icon_salut:
I remember a painful experience when I couldn't locate the original ,smaller, rear-brake-pedal in a hurry.
My 2000 has the same brake pedal, I have a piece that bolts onto the pedal making the foot contact surface larger. But these one piece cast aluminum pedals really don't like rocks. I have 2 pedals (one for back up) and they both have been broke and welded back together, damn things are too expensive to keep buying new ones.
I did not know that the newer pedals with the hinged end would fit the older bikes. I may have to look into that.
