davelewis Posted July 1, 2011 Report Share Posted July 1, 2011 i wonder if somebody could advise me on the best way to undo the flywheel nut on my fantic 245. The engine is out of the frame. It's extremely tight! Attempting to jam the sprocket didn't work. also, the rear shock is in poor condition - corrosion on the shaft etc. Is there an aftermarket alternative or a shock from another bike which will fit and do a half decent job? Thanks all Quote Link to comment Share on other sites More sharing options...
b40rt Posted July 1, 2011 Report Share Posted July 1, 2011 Air gun if you can get access. Quote Link to comment Share on other sites More sharing options...
davyb Posted July 1, 2011 Report Share Posted July 1, 2011 You can use a early Gas Gas txt shock, its the correct size and very little fettling to fit, got one on mine and is very good and you loose the duo shock remote. As for your flywheel try using a air tool, spining it fast usually does the trick, or take the head off and piston and put a rod in the small end without bearing ,two bits of wood on each end of rod and jam con rod on downward stroke. Quote Link to comment Share on other sites More sharing options...
fantic200 Posted July 1, 2011 Report Share Posted July 1, 2011 yep, barrel off and a 1/2"drive socket extension through the little end and a piece of wood at either side and a good 1/2" torque wrench of decent length will do the trick. Quote Link to comment Share on other sites More sharing options...
lee harris Posted July 1, 2011 Report Share Posted July 1, 2011 I wouldnt use the small end method....take it to a car wheel fitter and use his airgun if you dont have one . Will cost one pound me finks Quote Link to comment Share on other sites More sharing options...
grib Posted July 9, 2011 Report Share Posted July 9, 2011 There are two holes in the flywheel to hold it whilst undoing the nut, best thing would be to use them. Quote Link to comment Share on other sites More sharing options...
mcerem Posted July 12, 2011 Report Share Posted July 12, 2011 There are two holes in the flywheel to hold it whilst undoing the nut, best thing would be to use them. Yep, use a bar with 2 holes and bolt to fly wheel, then use your work bench as a 'back-up' to wedge the bar against as you try to slacken the nut. Your weight on the wrench as you try to slacken the nut should keep the engine and bar on the bench. Quote Link to comment Share on other sites More sharing options...
davelewis Posted July 14, 2011 Author Report Share Posted July 14, 2011 thanks for all your advice everyone, much appreciated. Nut taken off with air ratchet. Quote Link to comment Share on other sites More sharing options...
