EVO map setting
westygas270
Hi all Just wanted to know what setting people ride there evos on? Ive gone from a 2010 290 evo to 2011 290 evo allways useto have it on number2 but got told just to keep it on 1 and forget about it only second time on the 2011 but seem to find better grip with it on number2, not sure if it does make a difference but what does everyone use????
  On 7/4/2011 at 6:27 PM, Westygas270 said:
Exactly the same with mine, i think its ment to be the top end power but low revs setting off setting 2 feels better to me ??
ive got a factory rep and leave it on 1 as its much smoother on the bottom, number 1 is a beast off the mark.
I ride an 09 290 at very high altitude usually with good traction unless it rains. (7K-11k) I use setting one. It seems to have a stronger bottom pull with a softer mid to top. While the two setting seems to have a softer bottom pull with a stronger mid to top pull.
