smallboy Posted July 12, 2011 Report Share Posted July 12, 2011 Hi all I cannot seem to tighten the lever clamps on my BETA EVO,fully tightened still move,any ideas? Regards Quote Link to comment Share on other sites More sharing options...
dan williams Posted July 12, 2011 Report Share Posted July 12, 2011 Are you running stock bars? I can tighten the levers on my '05 Rev3 with Renthal bars but Tommaselli bars won't properly hold the levers. The grips still fit though. Apparently doesn't take much for the lever perches to slip. Quote Link to comment Share on other sites More sharing options...
smallboy Posted July 12, 2011 Author Report Share Posted July 12, 2011 On 7/12/2011 at 7:24 PM, Dan Williams said: Are you running stock bars? I can tighten the levers on my '05 Rev3 with Renthal bars but Tommaselli bars won't properly hold the levers. The grips still fit though. Apparently doesn't take much for the lever perches to slip. Quote Link to comment Share on other sites More sharing options...
smallboy Posted July 12, 2011 Author Report Share Posted July 12, 2011 Hi All standard fitment,any ideas? Quote Link to comment Share on other sites More sharing options...
jordi Posted July 12, 2011 Report Share Posted July 12, 2011 Warranty issue? Quote Link to comment Share on other sites More sharing options...
copemech Posted July 13, 2011 Report Share Posted July 13, 2011 Might carefully mark the positions, then give a couple careful wraps of the bar using the teflon pipe sealer tape. It adds just a bit of thickness and you can adjust the rotational friction to suit, as such they will still rotate in a crash, yet can be repositioned by hand with little effort. Quote Link to comment Share on other sites More sharing options...
dan williams Posted July 13, 2011 Report Share Posted July 13, 2011 Just a thought, the bracket at the bottom of the perch may fit one way. Try flipping them 180 degrees. Quote Link to comment Share on other sites More sharing options...
pa. Posted July 13, 2011 Report Share Posted July 13, 2011 On 7/13/2011 at 4:56 AM, Dan Williams said: Just a thought, the bracket at the bottom of the perch may fit one way. Try flipping them 180 degrees. Correct. The face that goes to the front is different from the rear face of the clamp. The tape on the bar is worth doing. Quote Link to comment Share on other sites More sharing options...
smallboy Posted July 13, 2011 Author Report Share Posted July 13, 2011 On 7/13/2011 at 6:09 AM, PA. said: Correct. The face that goes to the front is different from the rear face of the clamp. The tape on the bar is worth doing. Quote Link to comment Share on other sites More sharing options...
