TLR250 rear wheel bearing replacement
tlrider
Greetings Everyone,
I have just recently acquired a TLR250 and need to replace the rear wheel bearings. There is no online parts fiche available for this bike that I'm aware of and the parts fiche I've found that most resembles my rear wheel is an 85 XR350 though one of the bearing numbers does not match.
There appears to be a threaded retainer on the sprocket side of the hub that has four indentations to lock the ring in place, does anyone have a procedure for removing this retainer?
I'm also looking for the bearing numbers and dust seal number so I can order the parts before dissassembly. The brake side bearing is visible and is a 6202LU bearing. I can not see the bearing number on the sprocket side due to the retainer.
All help and suggestions are greatly appreciated.
This bike is an incredible improvement over my TL125 with modified rake and 166cc big bore, but I still love my TL!
