Villiers 150 to 200 conversion
loydee
Hi, have just acquired what I assume is a 150 Villiers engine with 55mm bore. The gearbox,primary & flywheel mag seem fine. Unfortunately it's seized, so rather than rebuild this probably underpowered unit, I was wondering if a 197 bottom/top end would fit into the existing gearbox,primary,mag set-up?
Thanks in advance...
Twinshock Blog
Edited by Loydee
