TXT 280 edition gear oil
airborn
Hi all, whats the best gear oil to use in my 280 edition 2003 not pro. some say light gear oil and some say dexron atf, what should i use? also ive changed a pipe on the rad and need to refill with new coolant how much coolant do i put in and do i have to bleed to stop air locks. Any idea whats the best coolant?
Many thanks Andy
Many thanks Andy
Andy, you can use either one. They will give slightly different clutch engagement, with the ATF maybe slightly quicker engagement. Try both and see which one you like. 650cc's is a good volume and change it maybe every 10-15 hours of use max and your engine and clutch will be happier.
Most of use a 50/50 mix of distilled water and auto anti-freeze with good results. You don't need to bleed the system but it's good to check it after running a short time just to be sure you don't need to top it off. Fill the coolant to the bottom of the filler neck and if you over fill it a little expect a little to dribble out the overflow tube at first (not a problem).
Jon
Jon
Thanks for that jon, thats good advice
Cheers Andy
