replacing dogbone bearings
avo
1- If you haven't done it before, take pics of each step, so you remember where washers went, or which way round Dust seals went.
2- To push the Bearings out, Get a Socket that sits on the Link itself, and is big enough to allow the bearing to enter it. And then a socket that sits on the outer bearing race, but is small enough bore to fit inside the Link.
you should see what your trying to achieve by now. If you have a Vice, then set it up as above and press the bearings out. This also works for pressing the bearings back in.
If you don't have a vice, ive simply hammered them out as above.
Really make sure before you start, that the Socket Pushing the Bearing out, is not too big or caught on the Ali body of the link, or else you will damage it.
Hopefully this all makes sense over Text!
Edited by hrc_monty
Works EVERY time for me, piece of p***. Just make sure you whack plenty of grease into them rollers, cos they come with margerine in from new!
  • 1 month later...
