electrics
pugslee
Hi Guys
Can anybody help
Can anyone measure the voltage that comes out of the lighting coil on a sherpa 350 199 model.
I am trying to fit lights and horn for mot and only get 2.4v on the red wire for horn,(6v horn fitted and does not make a noise when wired direct to earth or through switch). tested on a 6v battery and works fine. It is a new ign coil from bultaco uk. The yellow wire gives out 3.2v and is giving me a good brake light when pressed and not bad front and back light. but if i press the brake pedal with the lights on all goes very dim almost like a bad earth problem. all earths cleaned. i have disconected wires from magneto and replaced with a six volt torch battery to test and all works well.
any help very much appreciated.
Hi Guys
Can anybody help
don't need lights for mot.
Hi
i realise i dont kneed the lights for mot and yes i could fit a battery horn.
I have seen pictures of bultacos and videos on youtube with lights and horns so it must be possible. i would just like them on( and working)
Cheers
My memory of running lights on my Bultaco in the mid 1970s is that the 6V headlight bulb glowed dull red at idle, bright red at mid RPM and pale yellow at maximum RPM. If you brought the brake light on, the headlight went much dimmer.
I'm sure that you can get your lights to work very well with modern technology. There is a place in South Australia that specialises in setting up all sorts of dirt bikes for racing right through the night and they have been doing it since I was a kid in the 1970s. I would not expect that the standard lighting on your Bultaco will work much better than what you have found already.
