shedracer Posted August 15, 2011 Report Share Posted August 15, 2011 As I don't currently have a bike, I wonder if anybody could do me favour. Could someone measure the height from ground to handle bar end, with bars straight and also when bars are turned full lock. I need this measurement, to see if a bike might fit in a friends small box trailer. Cheers. Quote Link to comment Share on other sites More sharing options...
dombush Posted August 16, 2011 Report Share Posted August 16, 2011 hi My bike (gasgas pro) is 1140mm from the ground with the steering straight (highest part is the throttle housing) With the bike at full lock and the bike upright, the higher handlebar is 1300mm from the ground. hope this helps. Dom Quote Link to comment Share on other sites More sharing options...
shedracer Posted August 16, 2011 Author Report Share Posted August 16, 2011 Many thanks Dom, much appreciated. Quote Link to comment Share on other sites More sharing options...
bieze Posted August 16, 2011 Report Share Posted August 16, 2011 Many thanks Dom, much appreciated. If you put a strap over the bar and under the wheelaxle that can be a lot less, if necessary... Quote Link to comment Share on other sites More sharing options...
