brucey Posted August 16, 2011 Report Share Posted August 16, 2011 Hi, I have fitted a new ( Quote Link to comment Share on other sites More sharing options...
mcman56 Posted August 16, 2011 Report Share Posted August 16, 2011 How does it idle? Can you get a nice slow steady idle? Quote Link to comment Share on other sites More sharing options...
bashplate Posted August 17, 2011 Report Share Posted August 17, 2011 brucey, if the plug is sooty, then it's running rich and you may need smaller jets , and or lower the float level. have you tried ajusting the pilot screw setting? and maybe the needle clip? may just be due to flooding of the float bowl due to sticking or dirty float valve, that would be first thing to check. Quote Link to comment Share on other sites More sharing options...
brucey Posted August 18, 2011 Author Report Share Posted August 18, 2011 Tick over is steady and reasonably slow especially since reverting to the original jets. I seem to remember my old Cub being a little bit slower on tick over but that had a standard cam and this one has an R cam. I'll run it,do a plug chop and look at the needle adjustment if it's still sooty. Is there a seperate pilot screw adjustment? I thought you could only change the jet sizes. Thanks for your advise so far, it's given me a few more things to check. Bruce. Quote Link to comment Share on other sites More sharing options...
