Fantic 300 yoke stem removal advice?
isaacely
Hi, can anyone offer any advice on how to remove the stem from the bottom front fork yoke on a fantic?
Is it threaded or just pressed in?
Does it only come out in one direction?
Is it worth removing the tapered bearing first?
Is it best to heat the alloy bottom yoke before attempting to remove it or push it out, will it take a lot of pressure and risk smashing the bottom yoke?
I need to fit the yokes on another bike that has a thinner stem so need to remove this one so I can make a thinner one to fit.
Thanks for any advice you can give. Alan.
