bambam_n_chunx Posted August 17, 2011 Report Share Posted August 17, 2011 Does anybody know what causes a bike to run on after the throttle is closed off. I noticed my fantic does it quite a bit while queueing although it does run spot on once its moving. I`ve a 240 and have recently fitted it with a reed valve motor from a 245, it has been fitted with new mains and oilseals and the piston is okay. I used the 245 carb and electrics which I believe to be set up correctly. The engine is on the bench now as I needed to do some work on the bike so I would like to put it right before it goes back in. Could it need new reeds in or does that not cause it. Quote Link to comment Share on other sites More sharing options...
yeogene Posted August 18, 2011 Report Share Posted August 18, 2011 Does anybody know what causes a bike to run on after the throttle is closed off. I noticed my fantic does it quite a bit while queueing although it does run spot on once its moving. I`ve a 240 and have recently fitted it with a reed valve motor from a 245, it has been fitted with new mains and oilseals and the piston is okay. I used the 245 carb and electrics which I believe to be set up correctly. The engine is on the bench now as I needed to do some work on the bike so I would like to put it right before it goes back in. Could it need new reeds in or does that not cause it. Quote Link to comment Share on other sites More sharing options...
midlife Posted August 18, 2011 Report Share Posted August 18, 2011 Does anybody know what causes a bike to run on after the throttle is closed off. I noticed my fantic does it quite a bit while queueing although it does run spot on once its moving. I`ve a 240 and have recently fitted it with a reed valve motor from a 245, it has been fitted with new mains and oilseals and the piston is okay. I used the 245 carb and electrics which I believe to be set up correctly. The engine is on the bench now as I needed to do some work on the bike so I would like to put it right before it goes back in. Could it need new reeds in or does that not cause it. Sh-t petrol try adding octane boost as well as using super unleaded.And always use fresh petrol unleaded only keeps for a couple of weeks in a plastic container (plastic tank). Quote Link to comment Share on other sites More sharing options...
lee harris Posted August 18, 2011 Report Share Posted August 18, 2011 My bet is a worn carb (slide) If you close the throttle and the slide is awol, it will pull on by and let it run on as andy describes. Try another carb. Anyone will do I think you have enough.... BR L Quote Link to comment Share on other sites More sharing options...
bambam_n_chunx Posted August 18, 2011 Author Report Share Posted August 18, 2011 Thanks for the help. Lee, I replaced the slide when I built it up but I suppose the carb could be worn, i`ll try another carb, its possible I might be able to find another one or two. If it was running weak could it have the same effect? Quote Link to comment Share on other sites More sharing options...
