peterh Posted August 21, 2011 Report Share Posted August 21, 2011 Can anyone tell me the size of the 2 x o-rings between the main pipe and the mid-section of a 2009 Beta Evo. The dimensions for the internal diameter and the thickness of the o-ring would be ideal. I think they will be something like 62mm internal diameter and 2.5mm thickness, but mine are rather deteriorated. The parts book and the workshop manual do not give the size. Thanks for assistance. Quote Link to comment Share on other sites More sharing options...
twinkletoes Posted August 22, 2011 Report Share Posted August 22, 2011 (edited) good luck with this one.. my friend has a bearing shop and we must have trawled through my bodyweight in o-rings trying to get a match off the shelf, and didn't. also bare in mind they need to be heat resistant which most o-rings are not. if you cannot wait then get some off the exhaust shelf sealant in there from a motor factors, but you'll have it to clean out when you get the correct o-rings. simple solution- ring lampkins, they only cost a few quid and will be with you the next day usually. edit doh....just realised where you are!! Edited August 22, 2011 by twinkletoes Quote Link to comment Share on other sites More sharing options...
cyclist Posted August 24, 2011 Report Share Posted August 24, 2011 I found some at the auto parts store that seem identical to the originals. When I get home tonight I will try to find the package. I think the dimensions are listed on it. Quote Link to comment Share on other sites More sharing options...
cyclist Posted August 24, 2011 Report Share Posted August 24, 2011 OK, found the box. I got them at NAPA auto parts. The size on the box is: 2 7/16 X 2 5/8 X 3/32 inches. Sorry you will have to do the metric conversion. The NAPA Balkamp part number is 727-2143. Here is a link: https://www.napaonline.com/Catalog/Result.aspx?Ntt=727-2143&Ntk=Keyword&Nty=1&Dn=0&D=727-2143&Dk=1&Dp=3&N=0 Hope this helps. Quote Link to comment Share on other sites More sharing options...
peterh Posted August 24, 2011 Author Report Share Posted August 24, 2011 Thanks - looks like my measurements were about correct, so maybe the deterioration of my one surviving one is not too bad. 2-7/16 x 3/32 is 61.6mm and 2.62mm Found a useful sizing chart here: O-ring Sizing Chart - see row -143 on this chart. According to the specs for the Nitrile o-ring - can take up to 250 Quote Link to comment Share on other sites More sharing options...
