quert Posted August 21, 2011 Report Share Posted August 21, 2011 hi allgot a 2011 250 pro when starting i have to kick it over about five times before i can start it as if it has no compreshion when started it runs well and has plenty of power ! just wondered if this is normal or if any one else has a bike like this?? any ideas ?? Quote Link to comment Share on other sites More sharing options...
smalley250 Posted August 21, 2011 Report Share Posted August 21, 2011 From cold dont use any throttle just choke. Check float level on carb, remove bowel and turn upside down and the brass arms need to be 15mm - 16mm at tip end from the carb base. I did this as GasGas uk advised and never had any stating issues again. It most likley will be carb and your starting technic. Quote Link to comment Share on other sites More sharing options...
quert Posted August 22, 2011 Author Report Share Posted August 22, 2011 From cold dont use any throttle just choke. Check float level on carb, remove bowel and turn upside down and the brass arms need to be 15mm - 16mm at tip end from the carb base. I did this as GasGas uk advised and never had any stating issues again. It most likley will be carb and your starting technic. ok will try this and let you know Quote Link to comment Share on other sites More sharing options...
quert Posted August 24, 2011 Author Report Share Posted August 24, 2011 ok will try this and let you know all checked and all fine???? Quote Link to comment Share on other sites More sharing options...
