315 thermo switch problems
serious3
after 8 months and perhaps 10hrs riding the new genuine honda (expensive) thermo switch has died and its overheating, i'm skint as a result of redundancy :thumbup: so was wondering if i could wire the fan to be on all the time? just for a few months till i can afford a new one?
If you do that 'mod' remember that your fan will be running continuously along with your engine....something it was not intended to do.
It's a great field mod to get you home but that fan motor was only designed to complete 'so many' rotations in it's life span.
I reckon a new fan is 10 times more expensive than a new 'stat switch?
As always, the choice is yours, now that you have the relevant info :thumbup:
:blush: :blush: am i embarresed or what, went out and actually had a look at the bike after it had overheated and it turned out to be a loose connection on the red plug from the CDI :blush: :blush: so thanks for the replies and next time i'll actually look at the bike before i post on here!!
