zao9 Posted August 29, 2011 Report Share Posted August 29, 2011 Hi Recently purchased an Ohlins rear shock for my Beta. Have tried setting it up as stated in the manual but carnt get it in the tolerances.The travel difference is suppost to be 65-75mm from when nothings on the bike to when I am on the bike. I can only get it to 95mm. I think the spring may be the wrong one for my weight, but I carnt make sense of the serial code looked everywhere and still no joy. Any info would be gratefull. The spring number is 00281-15/70 L1011. and I am 13 stone with riding gear on . Thanks Jack Quote Link to comment Share on other sites More sharing options...
cabby Posted August 29, 2011 Report Share Posted August 29, 2011 Can't help you much other than... 40N = 6st 45N = 8st 50N = 9st 60N = 10st 70N = 13st 75N = 16st 80N = 20st Hope that in some way helps Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted August 29, 2011 Report Share Posted August 29, 2011 Information copied from http://www.ducati-upnorth.com/tech/suspensionspring.php How To Read An Ohlins Spring Code 1091-34/100 is an example of a code you will find on an Ohlins shock spring. Using the below charts you can Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 29, 2011 Report Share Posted August 29, 2011 my number is different to that,00281 is the same though will check tomorrow the rest. Quote Link to comment Share on other sites More sharing options...
zao9 Posted August 29, 2011 Author Report Share Posted August 29, 2011 Cheers does any one know wt weight that springs for then? Because that table doesnt make much sense! Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 3, 2011 Report Share Posted September 3, 2011 (edited) Cheers does any one know wt weight that springs for then? Because that table doesnt make much sense! mine is 0281 16/75 L3210 Edited September 3, 2011 by Nigel Dabster Quote Link to comment Share on other sites More sharing options...
splatshop Posted September 7, 2011 Report Share Posted September 7, 2011 Hi Jack We just added a little guide to the spring rates on our site, if you like to look you can find it here: http://www.splatshop.co.uk/ohlins-rear-shock-absorber.html Your spring is a 70N/mm spring and is about right for your weight but I did speak to our supplier and he mentioned that the Beta Evo's require a little more preload than the other bikes or possibly the next harder spring. We can supply you a new spring,email me if you are interested. Quote Link to comment Share on other sites More sharing options...
