richard400 Posted August 30, 2011 Report Share Posted August 30, 2011 Can someone tell me how to get the bowl off the carb on a 2006 TXT. There aren't any visible fastenings. Or am I missing something? Thanks Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 30, 2011 Report Share Posted August 30, 2011 How about the big brass nut on the bottom? Quote Link to comment Share on other sites More sharing options...
richard400 Posted August 30, 2011 Author Report Share Posted August 30, 2011 How about the big brass nut on the bottom? That drains the bowl and gives access to the main jet but doesn't release the bowl. Quote Link to comment Share on other sites More sharing options...
jandyb Posted August 30, 2011 Report Share Posted August 30, 2011 That drains the bowl and gives access to the main jet but doesn't release the bowl. Oh yes it does -Jan Quote Link to comment Share on other sites More sharing options...
billyt Posted August 30, 2011 Report Share Posted August 30, 2011 It does afford access to the jets thru the big brass nut. It is stuck due to not being open much. Hit it with a big piece of wood or a rubber mallet. If that does not work then heat it up with a hair dryer pointed at the bowl and then hit it?????? Quote Link to comment Share on other sites More sharing options...
ham2 Posted August 31, 2011 Report Share Posted August 31, 2011 Go easy on the 'hitting' it's only magnesium alloy(?) If the carb's on the bench just grip the bowl with some emery paper in your hand and pull/wiggle. The chances are that (once the brass nut is off) the bowl is just hung-up on the o-rings. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted August 31, 2011 Report Share Posted August 31, 2011 It does afford access to the jets thru the big brass nut. It is stuck due to not being open much. Hit it with a big piece of wood or a rubber mallet. If that does not work then heat it up with a hair dryer pointed at the bowl and then hit it?????? As above they usually stick to the gasket so a very gentle tap with a soft mallet is all that is required!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
richard400 Posted September 1, 2011 Author Report Share Posted September 1, 2011 Thank you Gentlemen. My experience of Gas Gas (trial and enduro) is not to go anywhere near it with anything stronger than a feather duster. Fastenings in particular seem to be made from the softest steel known to mankind. I'll start with a very gentle tap..... Richard Quote Link to comment Share on other sites More sharing options...
