digga Posted February 14, 2012 Report Share Posted February 14, 2012 what map are you on? Map 12 there are no issues. also, make sure you give it a good 6th gear run from time to time as you would all trials bikes to keep it breathing right. Also, no one should adjust the trottle body without setting the throttle position with the diagnostic tool. My golden rule to everyone, please don't touch the throttle body. cheers Hi borus,sorry for the late reply,have now drained the tank and will remix some different brand fuel/oil and give that a go! I contacted my dealer who is in another State (about 700 klms away),he has now confirmed it is still running (Map-11) not (Map-12) as you suggested,even though the bike is only 4weeks old! The dealer is just about to supply another one of his franchise shops with the "Ossa" diagnostic equipment which is about 80 klms away so when that is up and running maybe i can get (Map-12) installed,which might help things as well? Regards. Quote Link to comment Share on other sites More sharing options...
borus Posted February 14, 2012 Report Share Posted February 14, 2012 map 12 will sort things out for you - cheers Quote Link to comment Share on other sites More sharing options...
sunlingkau Posted February 14, 2012 Report Share Posted February 14, 2012 ............ Quote Link to comment Share on other sites More sharing options...
sunlingkau Posted February 15, 2012 Report Share Posted February 15, 2012 good luck dani this year Quote Link to comment Share on other sites More sharing options...
taff_d Posted March 2, 2012 Report Share Posted March 2, 2012 This starting gizmo is not a freebie if you want it you have to pay for it, this info came from the factory. Quote Link to comment Share on other sites More sharing options...
jsp Posted March 2, 2012 Report Share Posted March 2, 2012 how many pennys Quote Link to comment Share on other sites More sharing options...
taff_d Posted March 2, 2012 Report Share Posted March 2, 2012 (edited) how many pennys They never said, probably not cheap ! My dealer says you replace the black box on the front and the new one houses battery's, you also get a switch to turn the battery's on and off. So basically the battery's are just giving you a more powerfull spark when needed. Edited March 2, 2012 by Taff_d Quote Link to comment Share on other sites More sharing options...
jsp Posted March 2, 2012 Report Share Posted March 2, 2012 interesting times then eh only time will tell jsp Quote Link to comment Share on other sites More sharing options...
deonattard Posted April 1, 2012 Report Share Posted April 1, 2012 This starting gizmo is not a freebie if you want it you have to pay for it, this info came from the factory. Any idea when and where we can order the battery? I can start mine but its not easy and by the time I start my Fathers as well I'm ready for a cup of tea and a lay down!! Quote Link to comment Share on other sites More sharing options...
toothandnail Posted April 2, 2012 Report Share Posted April 2, 2012 I hardly EVER kick more than 3 times , except yesterday , rode about 10 min, shut it off , kicked about 15 times NOTHING , then I checked the fuel , MT ! Fueled up started 2nd kick Quote Link to comment Share on other sites More sharing options...
deonattard Posted April 2, 2012 Report Share Posted April 2, 2012 Ours are about 5-6 kicks from cold, first kick when hot or when left to sit for less than an hour. After starting mine, and then my fathers I'm ready for a rest!! Soon as anyone can get me two battery packs let me know as I'm desperate to order them and don't really mind where in the world they get shipped from. Quote Link to comment Share on other sites More sharing options...
jsp Posted April 2, 2012 Report Share Posted April 2, 2012 the ISS starts wont be out for another couple of months, what years are you bikes as the are sometime easier to start once they have bed in, mine is just a bugger from cold and it takes 7 or 8 kicks once hot its ok but if you leave it a bit to cool down its back to 7 or 8 kicks jsp Quote Link to comment Share on other sites More sharing options...
deonattard Posted April 3, 2012 Report Share Posted April 3, 2012 (edited) the ISS starts wont be out for another couple of months, what years are you bikes as the are sometime easier to start once they have bed in, mine is just a bugger from cold and it takes 7 or 8 kicks once hot its ok but if you leave it a bit to cool down its back to 7 or 8 kicks jsp We have a 2011 and a 2012, they are both supposed to be on the 12 map although I havn't verified this with my own eyes. Can anyone confirm if the 13 map is a significant improvement in starting? I started mine tonight and it took at least 10 kicks, it was dark by the time I got it going so I didn't get to have a ride and in the end I kept kicking just to make sure it would start... It did start with me standing on the ground though, every other time I've had it leaning against something which allows you to give it a better kick. There has to be an easier way though, we are doing an event this weekend and I'm worried Dad will need me to start his and I'm going to be knackered if I have to get them both running!! Edited April 3, 2012 by DeonAttard Quote Link to comment Share on other sites More sharing options...
jsp Posted April 3, 2012 Report Share Posted April 3, 2012 i will let you know mines going in tomorrow for map 13 putting on it jsp Quote Link to comment Share on other sites More sharing options...
sunlingkau Posted April 3, 2012 Report Share Posted April 3, 2012 map 13, map 12 are one kick me . even cold engine...... bear in mind 0.8-0.9% 2T mix is good enough for your TR280i Quote Link to comment Share on other sites More sharing options...
